3800 guys: Dyno tips?
Harbor Master
My gee tee pee might get dyno'd here soon for kicks...
any hints/tips to make sure it puts down the most accurate number (cough, highest, cough couch :wink: :wink:)
El Presidente
Lock the converter. Then you can make "big" numbers like HK.
Harbor Master
i think i can do that via hptuners
Harbor Master
[MENTION=98]smug[/MENTION] [MENTION=53]Turbocharged400sbc[/MENTION] [MENTION=12001]whatever[/MENTION]heavykevysusernameiscurrently
Harbor Master
[MENTION=517]10sec[/MENTION]
PANDA
FRG
Just have use Modern Muscles dyno
Harbor Master
this is going as expected.
Harbor Master
[MENTION=11585]twinv6gtp[/MENTION] any tips from you brother in the north?
Harbor Master
imma slap that dooobie outchyo hand [MENTION=53]Turbocharged400sbc[/MENTION]
Over inflate the driven tires. 40 psi to reduce rolling resistance from strapping it down. ..
Dyno with fresh air supply in front of car....speed inc sucks for fwd...your dynoing with egr in that building lol...
Garden sprayer with ice water sprayed on core...or leaky nitrous bottle and 1/4" copper tube....
Clean filter and britches
smug
Cedar Lake, IN
Before dyno day I would do street tuning and make sure you have zero kr from mid second gear all the through 3rd gear. I was dynoed in 3rd gear so what ever 6500 rpm is 3rd is, is what mph they stoped the dyno at. Don't be switching up you fueling or gas mixture.or anything after you find out what works the best for you. I didn't lock the converter or anything special. Just strapped the bitch down and let her have it.
1quick
coal city
Dyno in 3rd and lock the converter or disable the trans pressure switch to tighten the converter
10sec
KJ, just dyno the car and see what it makes. Don't lock the converter, up the tire pressure, that's all so stupid. You're not going to break any records, you have a perfectly good reliable car, don't fuck around with it.
OffshoreDrilling
This is my safe space
Chicago
came in to suggest fire extinguisher, glad someone already had their wits about them
jdredd
If dyno shop insists their guy has to be behind the wheel,
make sure they hold on with both hands.
Our local shop guy never dynod a FWD car with torque apparently.
so it pulled the wheel out of his one handedness, and car went to zero in a no time as it came off the rollers.
jdredd
make sure insurance is still valid....
