I don't know whether to post here or in my 'el tortuga' thread at this point but since the season is over and i'll be putting the turtle into hibernation after this weekend, here's the update.
FGT setup has some miles on it. - speaking of which, I've never seen my gas gauge go from freshly filled to 3/4 so fast as today - no joke 20min of driving
I did not make it to the track either of the two weekends I was planning because it was closed due to weather both times and it's probably for the best because as fate would have it, they would have pretty much been wasted days anyway.
The first week I figured out that my breaking up issue at full load was due to lack of fuel primarily on account of my easyperformance voltage booster quitting on me. It was working in pass-through and not boosting voltage ever. I threw my old magnavolt back in there which is a bit less juice but enough to eliminate the breaking up issue. I found out today that it's definitely still not enough but If I keep the boost down below 20psi or so, it keeps up and that's a nice bump in power still.
Oh the second day that I would have gone to the track, my old tuning laptop just sorta stopped booting up which kinda screwed me over too. That would have ended my 2nd would-be track day right away.
Today, I had some time and after getting my newer laptop set up for logging, I did some good road testing and got some good info. The thing makes fuckin power. with the exhaust completely choked with stock mufflers, I was still seeing up to about 11300hz at the maf after 70% scaling. Boost currently is steady 20psi until the upper 5k rpm and then it peaks up at like 23 and then fuel pressure very quickly starts disappearing. That's with the cutout closed and on that note...
After my driving around I spotted this and was like wtf obviously
then I looked underneath and saw this. Both new mufflers are literally busting open at the seams.
They can't handle the 3800 powers
What else?... I got the LS ignition all done with new wiring. It's been working fine. I installed my electric water pump. Works great as far as I can tell. All the wiring I did for the LS ignition, water pump, IC pump, etc. I integrated into the factory fuse/relay box under the hood using the unused spots in there so there's no more relays and shit just hangin out places. New boost controller works awesome which is a godsend after the nightmare I went through trying to make the easyperformance one work for me.
I've got some in-car footage on my gopro - i'll trim all the nonesense out and post it soon. Nothing too nuts
