generator
i hope it's cool.
Sounds like it'll just use the hybrid batteries as a power station, which could be cool, depending on how many kW the battery pack is, and how many watts it'll handle.
The 2.0-kW system is available on the F-150’s equipped with a gasoline 2.7-liter, the 3.5-liter Ecoboost V6 and the 5.0-liter V8 non-hybrid engines. Power is accessed via two standard 120-volt, 20-amp outlets in the bed, nearly identical to the electrical outlets in your home). Its best suited for tailgating, light-load camping or powering small electrical devices.
The 2.4-kW is standard on the 2021 F-150 when equipped with the 3.5-liter V6 hybrid “PowerBoost” engine. Electricity is accessed through two standard 120-volt, 20-amp outlets in the bed, and Ford claims an 85-hour run time on a single tank of gas. For people who often go off-the-grid, the 2.4 kW system could eliminate the need to lug around a noisy and thirsty standalone portable generator.
The 7.4-kW system is optional on the 2021 F-150 PowerBoost. It offers four bed-mounted 120-volt outlets and a dedicated 240-volt circuit. Ford claims it will run for 32 hours on a full tank. This system is designed for the serious user and is robust enough to run a small construction site or power a mobile mechanic’s toolbox.
In the case of the Pro Power 2.0 kW system, the electric energy comes from the vehicle’s existing 12-volt battery, converted to AC by an onboard HD inverter. It’s pretty basic stuff and operates similarly to what’s readily available in the aftermarket, but comes fully integrated and warranted from the factory. Although functional, the 2.0 system lacks the robust properties of hybrid-based systems.
The 2.4- and 7.2-kW Pro Power systems are in an entirely different league. Both leverage the F-150 PowerBoost’s existing hybrid hardware, including the liquid-cooled 1.5 kWh lithium-ion battery pack. (A standard 12-volt battery is reserved for starting the vehicle.)
When activated, current travels from the battery to an onboard inverter that converts it to AC. If the battery charge gets low or demand spikes, the vehicle’s engine will start and recharge the battery via the drivetrain’s integrated 35-kW (47 horsepower) electric motor, which also functions as a generator (remember, it’s a hybrid).
2021 Ford F-150 Hybrid Truck’s Pro Power Onboard Generator Explained
Ford's 2021 F-150 V6 PowerBoost hybrid truck comes with an innovative onboard generator system called ProPower Onboard. This is how it works.
www.forbes.com
