2010 Camaro RS V6 idle fluctuates
SaturdaysGS
Chicago (Southside)
Was just curious if anyone has heard of this "problem". Basically the RPM's fluctuate 50-100 rpm up and down all the time, fairly quickly (you can see it with your naked eye on the tach) when it's idling, and even when you're cruising at say 70mph at 1700rpm. I KNOW it never did this when it was new or the numerous other times I've driven it, however I'm not exactly sure when it started. I was just told it started a couple months ago.
I Googled it and saw something similar but most of the complaints I've read are of the engine shaking / or a misfire type issue. The engine doesn't run rough nor is there a check engine light.
I know I could (should?) take it to the dealer, but it's not my car I'm just driving it temporarily as the person that owns it has a broken foot. It should still be under warranty (2010 ony 21k miles) but Idk if they will want to charge a diagnostic fee?
Thoughts?
-Nick
RICH17
Dr. Pussy Slayer, MD
The 007
Post up on a 5th gen forum about it. Im sure someone there would have a better idea
bikrboy128
Some say.....
Wheaton
the car has a bumper to bumper warranty. they better not hit you with a diagnostic fee
Turk
Lt. Ron "Slider" Kerner
Take it to the stealer.
boostedguy05
not well known
They won't find anything. They couldn't find the misfire on my car with it throwing codes. While having the car for two days. Stupid techs.
ProjectGTP
Change the plugs?? Also i heard the dbw throttle body gets dirty and causes weird idle problems, so people take throttle body cleaner and clean the throttle blade. But your car only has 30k miles so I don't know.
Chester Copperpot
TCGs Far Right Leader
Shithole, IL
My car does it too but only at idle. It bounces between 550-600.
If it's doing it while cruising that's a problem. Take it to the stealership.
dbw tb's are very susceptible to low resolution airflow control, especially with gear wear and even minor coking around the blade edges.
takes a crapload of coking to affect a std IAC pintle and its much finer per step air control.
just the nature of trying to use a large area butterfly valve for finite air control :rofl:
but hey its progress right? enjoy it sucka :jg:
02BlueGT
No Fucks Have Been Given
Now apearing in Hanover Park
The DBW GPs have an issue like this, clean the throttle and throttle blade with some carb/TB cleaner and problem solved. It has been reported from 20k miles and up, but usually around 60k
