GM 2004 XLR engine R&R help needed
daturbosix
Forum Sponsor
well not actual help.
im looking for the engine R&R procedure that i cant seem to find anywhere
:dunno:
anyone got access to dealer manual or mitchell or alldata for this?
please let me know.
thanks.
OffshoreDrilling
This is my safe space
Chicago
i can get you alldata when i get to work in the AM. I have access to it, but have a mac computer at home which isn't compatible.
daturbosix
daturbosix
Forum Sponsor
hit me up in the morning if youre able to pull that stuff up and get it to me somehow.
BOPC_Fan
Active member
Palos Park
You are going to have to drop the entire drivetrain attached to the subframes with suspension components out from the bottom. It has a torque tube and rear mounted trans like a Corvette. Don't even attempt to try and pull it from the top. Even in the STS with a Northstar we lower (not remove) the front subframe just to pull valve covers. Why are you pulling the motor anyways? Cylinder block cradle oil leak?
Kaeghl
Aurora, IL
oh crap. I recall that they are very similar/ based on a corvette. SO youhave to drop everything from the subframe.
BOPC_Fan
Active member
Palos Park
I can try and get you the service procedure straight from GM's Service Information website when I get a chance
Primalzer
Oh yeah, took a decent chassis, and put a leaky boat anchor in...
BOPC_Fan
Active member
Palos Park
The RWD Northstar is completely different from its FWD counterpart. They don't have the same issues the transverse motors do like piston slap or headgaskets. Yes they do leak oil but if looking actual design of the motor, its pretty stout and has the capability to handle decent power. The only reason they leak is because of the climate change and the extreme hot and cold cycles. Down south they are dry as a bone
daturbosix
daturbosix
Forum Sponsor
my customer has more money than he knows what to do with.
the car leaks everywhere, only has 18000 miles on it.
was his fathers that recently passed away.
he wants us to yank it out so he can take it to get rebuilt and head studded.
P40E
Is this the 4.2 or charged 4.4 ? Sweet car , just low on hp . The v does like mid 12's . The smaller n/a had like 320hp or something .
BOPC_Fan
Active member
Palos Park
Since the cylinder block cradle and most likely the front timing cover is leaking, make sure you use sealant on the timing cover, cylinder block cradle, and on both sides of the aluminum plate gasket in between the oil pan and cradle. Replace the crank main seal and check the crank pully snout for out-of-round. GM's part manufacturer for those (which are specific to the XLR) machined them that way on accident. GM since dropped that manufacturer, and that pully has been discontinued since '09ish. Just make sure that is all good cause if not, it will leak again. And soon.
