Long story short my dad an I built the pontoon I have now several years ago for him, he went cheap on the sound system, I ended up buying the toon from him when he was ready to upgrade, and now it's time to upgrade from 4 Jensen marine 5.25's running off head unit power
My plans, I'm going to run eight 6.5" audio pipe marine speakers and a jl 10" sub off a jl 600x6 amp, the speakers I just used on another small build with a similar amp so I could make sure they sounded ok and would handle the power, I know the sub is fine I run the same set up in my other boat, I'm doing 4 of the speakers in small boxes I found on Amazon and 4 under the back seat free air, the sub is also going into a ported box adding a battery and a switch too, here is the stuff, and trying t keep this project cheap I traded labor for all of the audio equipment, I've got about 350 into wire cables, cable ends, boxes, battery switch pretty much everything to install the whole deal
