1quick's marine audio build thread
1quick
26,554
24,013
coal city
Long story short my dad an I built the pontoon I have now several years ago for him, he went cheap on the sound system, I ended up buying the toon from him when he was ready to upgrade, and now it's time to upgrade from 4 Jensen marine 5.25's running off head unit power
My plans, I'm going to run eight 6.5" audio pipe marine speakers and a jl 10" sub off a jl 600x6 amp, the speakers I just used on another small build with a similar amp so I could make sure they sounded ok and would handle the power, I know the sub is fine I run the same set up in my other boat, I'm doing 4 of the speakers in small boxes I found on Amazon and 4 under the back seat free air, the sub is also going into a ported box adding a battery and a switch too, here is the stuff, and trying t keep this project cheap I traded labor for all of the audio equipment, I've got about 350 into wire cables, cable ends, boxes, battery switch pretty much everything to install the whole deal
1quick
26,554
24,013
coal city
This is what I'm using for the front 6.5" speakers, in a quest to water proof them somewhat so they don't crumble due to being mdf, I decided to try coating them inside and out with fiberglass resin, turned out pretty decent I went right over the carpet and let it soak in, it turned out with a finish that is similar to rhino liner
Before
After
