Is this in an aftermarket fuel cell type setup? If so, you will just need a check valve. The large vent is to allow the large amount of air back in when your fuel pump is doing it's magic. Many times it will be plumbed to outside the vehicle in case of check valve failure (may be required by NHRA rules actually).
