fixed
Damn I hate making mistakes! Thanks for catching that
96-98 are different from 99-01 motors in the heads intake also.
96-98 are "B" heads
99-01 are "C" heads
You CAN'T interchange heads with out doing the whole top end.
Awesome, thanks for the info, gents. How does the torque arm mount up..like a camaro?
No torque arm.
Trianglated 4 bar/link.
Same setup since 1979 to 04
Thanks. I didn't feel like continuing on about the heads too. Saved me some time.
The torque arm bolts to the rear center section of the 8.8" solid axle rear end with a few modifications. The front bracket will bolt to 8 metal tabs that will weld to aftermarket subframe connectors. Install takes roughly 4 hours if the subframe connectors are already installed.
He was referring to the aftermarket torque arm that I had previously mentioned, not the stock suspension setup.
All of that stuff I would likely never even get into. Whatever I get will be a DD.
to be quite honest eric, i would try and sell the impala privately....unless you can find another dealer to give you 5,000, you're gonna get hosed on trade in.
Idk why, but Autotrader has never sold a car of mine. I've sold close to 60 on Craigslist though lol.
The only thing that sucked was coming to a stop on an incline. Once that happens you end up traveling up the hill sideways with the car revving around 4K the whole time.
