1996 Jeep Cherokee - Lifted - $2000
Chrisco
is a work in progress
Downers Grove, IL.
This is being posted for my friend Jeff Hlavac, who can be reached at 630-939-0765, or by email at [email protected]. You can also contact me here through PM, call at 630-310-0929, or email at [email protected]
1996 Jeep Cherokee
147k
4.0L HO Inline 6, bulletproof engine
4x4, t-case works great in 4 hi and low
7” Rusty’s suspension lift
Rough country tracking bar with lowering pitman arm installed (new)
33” M/T mud terrains on Craiger rims
Quick-release pins on sway bars for off-roading
K&N intake
Aftermarket headers
Alpine flip-down cd player with aftermarket speakers installed in the doors, tailgate and sound bar on ceiling, sounds good, wired up for amps in back as well
Cobra CB installed in dash, works great, just need antenna, mount and wire already run to the back
New u-joint for rear axle
New transfer-case lowering kit
New battery installed in February
New starter installed in February
New wheel bearing installed in March
The bad:
Engine runs rich, I think it is a bad temp sender to the ECM, if I have time, I will look at it
Some play in the steering, as with all lifted trucks, components wear, I think it just needs some tie-rods, but I have not looked at it
Rear-end growls; never got worse since I had it, the fluid looks good and the diff works great, it is just loud
Will need a brake job soon, can work something out to solve this before the sale
The truck has been off-road, so it has some battle wounds, no rust on the body work, just scratches from trees, etc.
The truck turns heads everywhere it goes; it looks mean and has a ton of ground clearance. It would make a great off road vehicle, or with a little work, a great DD
$2000 obo
Harbor Master
that thigns fucking cool. i miss mine.
