• As many of you are aware, TCG experienced downtime at the beginning of May. Unfortunately, we had to restore the site from a 2023 backup. If you created a new account after August 2023, it has been lost and will need to be recreated. If you're having trouble logging in, please use the "Contact Us" form and I’ll address it right away. - Mook
đź§° BUILD 1989 Dodge Daytona ES TBI to Turbo Conversion
WarlockSyno
Oct 27, 2020
74
296
Gotta say the first box I took apart I almost puked from the smell of it burning 3-4 up. I bet that is pretty similar. Love the welded clutches, mine just turned into warped blu d steel.
Surprisingly it didn't smell as bad as some of the other stuff I've pulled apart, that's probably because I accidentally "flushed" the trans fluid when I pulled the axle the first time I had the motor out.
WarlockSyno
Oct 27, 2020
74
296
Got the trans fully apart. What a disgusting piece of art.
  • Wow
Reactions: IDAFC21
Mr_Roboto
23,569
25,949
Reactions: m_dogg and IDAFC21
WarlockSyno
Oct 27, 2020
74
296
I feel like I should clean up the case a little more before I start shoving stuff back in it. I used two whole cans of oven cleaner and it's still not pretty. :ROFLMAO:
Shops around here want $100 to clean it too. I'll do a little more hand cleaning then show some progress pics. All of the internals are minty clean after the sonic cleaner. So now I just need to tear down the 31TH and combine the two. Hopefully will be making a video comparing the differences between the A413 and the 31TH.
WarlockSyno
Oct 27, 2020
74
296
Was trying to get clutches to fit in my direct drum and nothing would fit. With all the factory stuff in it came out to .0005" (You read that right) of clearance. Well turns out my bonneville spring was broke. -__-
Took one out of another transmission and wam bam, now I have .009" of clearance with a .060" snap ring, so need to get a thinner snap and I'm good to go
WarlockSyno
Oct 27, 2020
74
296
I swear I'm still working on this guys. Just taking me forever because I've never done a transmission before. Plus don't really have the greatest of tools for transmission stuff.
Tapped the case for the accumulator in case I want to delete the accumulator in the future. 1/8" NPT plugs. So if I want to make the shift even firmer I can remove the middle accumulator and put these plugs in.
Locking down the transfer gears is fun. They require 200lb*ft of torque and these use a swappable spacer under them to adjust preload. So lots of torquing and removing, which is kind of difficult considering I have literally nothing to strap this transmission too lol. My work bench has wheels on it, so it's not stable enough to hold it. All my other tables are light weight metal.
Tried using a pair of cut proof gloves to jam the gears together for torquing. Nope.
I'll probably be building a tool like this:
I already built one for the 2.2/2.5 that can be flipped over and used for a 2.0/2.4 Chrysler engines.
WarlockSyno
Oct 27, 2020
74
296
Alright. Back to building! Parts here and now I'm getting stuff together.
The one way sprag uses these tiny little springs and bearings that need to be help in while you flip it upside into the transmission. A friend suggested using a roll of tape... I'll be damned.
So going to be getting stuff going. I'll give y'all updates when there is cool milestones.
NO PUKESTERS
84,404
36
You'd like my trans rebuild thread... We had all sorts of jollies using shit around the shop to compress shit
Reactions: WarlockSyno
20,238
42
Meant to watch these the other night. That was actually pretty interesting to me. But I have always been a fan of those "spot the difference" challenges :LOL: It is actually kinda amazing how little differences there are, being 10 years apart. But the improvements that have been made seem quite significant.
And the follow up vid :LOL: I agree! Send that bitch!
