1988 Mercedes 190E 2.3L - Maintenance
skeezer
Luke's Beef
Friend just bought a 1988 Mercedes 190E 2.3L (auto) with 96,xxx original miles. Car looks great, but is dying out when it comes to a stop. Runs well when driving, but sporadically dies out when coming to a stop.
Suggestions on what the problem may be?
DanJoy
My guess is alternator and connections to and from it.
Runtz52
Manhattan
i had a similar issue in my lumina, yes im aware these vehicles are very different, mine was due to the alternator and the pcm relay
epik_x
If you are braking, check for a vacuum leak, especially around the brake booster, or maybe the brake booster diaphragm itself is leaking. Worth a shot if its not any electrical connections.
bikrboy128
Some say.....
Wheaton
is it fuel injected or carb?
i've run into a few older carbed mercs that have had this same issue. the choke cable sticks at the carb body, causing it to die at idle.
