🔧 BUILD 1988 911 Hotrod Build
Picked up an 88 911 back in June. Haven't done much with it since. Just sold my M3 last week, so now the garage space is freed up.
The car was found locally. It spent it's short useful life up in Lake County. The original owner put 99,000 miles on it in about 12 years then blew the engine. The car has sat ever since. The body is in 100% original condition. There are actually no dings in the metal. No rust either.
I've got a rebuilt G50 trans for it. And a heavily modified engine. The engine case started as a Carrera 3.2, same as what this car came with originally. But is now a high compression, twin plug, carbureted 3.6. 370hp at the crank.
I'm not going to do anything to the car as far as paint. Leaving it as is. I am going to get the wheels redone in the RSR finish.
IMG_20191008_192313.jpgIMG_20191008_192353.jpgIMG_20191008_192405.jpgIMG_20191008_192430.jpgIMG_20191008_192500.jpgIMG_20191008_192527.jpg
GG Allin
Addict
Feb 27, 2012
763
583
ORD
Car is basically done for now, it'll never be done. I'll always have something to tinker with on it. But the plates are renewed, insurance is renewed for another year. The car is together and will be heading up to Perfect Power in Buffalo Grove for some final dialing in, alignment etc...then it's time to enjoy it
GG Allin
Addict
Feb 27, 2012
763
583
ORD
Just went right ahead and took the engine apart. Doing a full rebuild. Now that it's apart it's very clear that it didn't really need it. Engine was built around 20 years ago and previous to me has only "race mileage". It's getting a new crankcase, new lower compression pistons and new cams. Everything else will be refreshed and reused. Reason for the crankcase switch is the fact that someone messed with the engine number, no bueno. The new case is actually very closely date matched to the car, so there is that. Maybe I'll build the old one up as a spare. Also lower compression to get away from straight 100 octane. The engine dyno'd at 360hp 290 tq back when it was built. Hopefully it stays close to that.
GG Allin
Addict
Feb 27, 2012
763
583
ORD
Interesting thing I learned about the rods in this motor, they're roughly 134mm in length. I think they're actually 5.25 inches. Stock rods are 127mm and some of the newer GT3's have 130mm. From what I can gather this allows the motor to sustain higher rpms for longer (doesn't have to work as hard). If the cams are ground to take advantage of this, magic happens. Needless to say, the pistons are a one off set.
Pressure Ratio
20,514
12,424
Glen Ellyn
The rod ratio effects the speeds of the piston in different areas of the stroke. That longer rod helps slow the piston speed on the mid stroke and at top dead center. Which should help with the higher rpm. Plus the pistons are typically going to have a shorter pin height and skirts. Making it a lighter piston. Definitely a nice upgrade for a hot rod motor.
GG Allin
Addict
Feb 27, 2012
763
583
ORD
11.5 down to 10.3. The engine architect, William Knight supplied me with new cams. He believes I might actually gain some power. I'll believe it when I feel it. He's seen good results with them in other engines. They're one of his his proprietary grinds. This was one of "his" motors when it was originally put together back in '99-2000. There's been a lot of aftermarket cam development in those 20+ years.
Mr_Roboto
25,920
31,102
If he built it, I'd think that he'd be the person to know. I'd be curious if it would be at the expense of valve train longevity but I could see 20 year newer lobes doing better these days, especially with the advances in springs alone. Definitely not apples to apples. For that difference the you're probably talking 4%ish with the compression alone.
