It's alive! Got some wiring finished up (roughly) and fired it up Friday. No major issues or leaks upon startup, let it get up to temp and topped off fluids. Everything seemed pretty good, just a lot of smoke from all the paint and exhaust wrap burning off.
Couple of revs and it died on me, so I re-fired it and it wouldn't idle without 10% throttle input. I'm a total rookie on the Holley software but I noticed that IAC counts were very high @ 90% so I figured it needed the blade opened more. I flipped the idle set screw and opened it up a bit more, did a TPS Autoset, and it was all good. Holley made it so easy to fire up, I will never go back to HPTuners.
Took it down the street to the gas station, drove pretty nice for a wizard tune. First impressions:
-Front tires are too wide and rub on the fender on bumps.
-Exhaust leak somewhere up front, maybe the crossover pipe.
-Steering has some play in it on center, might look into tightening up this rack or maybe something a little more radical. Also needs an alignment badly. I will have that performed after I replace the front tie rods and ball joints which are thrashed.
-Brakes have a slight pulsation from sitting so long, we'll see if they clean up with additional miles.
-Differential has a healthy leak. I changed the fluid a few months ago and it weeped a few drops but once I drove it the oil came out at a much faster pace, so maybe something is wrong with the vent.
Overall it's a great cruiser with a ton of style. I can't wait to further refine it; once the small bugs are worked out I'll put on the charge pipe and see what it feels like in boost.
Here are some photos of driving around and after I washed it.
