shit is way too fancy. Plus that's the Jag/Ford era. Mine was built by British craftsmen, aka chain smoking English drunks fighting at soccer matches and building meh carsI saw this the other day and thought of this.
I am going to use a single external on this for ease of maintenance/replacement. Trying to keep on a budget so it's not practical at this point to buy one of those fancy drop in hats that supports internal pumps.Great updates. I was looking at the dual fuel tank on my FiLaw's '83.
Are you going to run 1-2 Walbro style pumps?
The 20 gallon actually sits just a bit below the shoulders of the trunk liner so I can just make a new floor out of some plywood and carpeting and call it done. I cut up the original trunk floor cover to use as an insulator between the cell and the sheetmetal, and with the size of the car (aka bad economy) and additional fuel requirements of E85 I wanted to get as much capacity as I could.It would probably be tight but I wonder if the 17 gallon I used would fit in and even be flush in that setup.
Very nice.I am going to use a single external on this for ease of maintenance/replacement. Trying to keep on a budget so it's not practical at this point to buy one of those fancy drop in hats that supports internal pumps.
Yeah I would think you could technically have the pump fairly far away (like 5', under the car), but as long as it's mounted level with the bottom of the tank, gravity will continue to feed it regardless.Very nice.
I'm cruising on an external Bosch 044 (runs from one sump line) and plumbed up a 2nd pump for big boost.
A friend of mine has a swapped '67 Chevelle and his external pump is kinda far away from the sump but I've never seen him have problems with it.
They are out there in nice shape, just have to keep your eyes open. That price is crack pipe though for a non running car. I paid WAY less for mine in non running condition.1986 Jaguar XJ6 - cars & trucks - by owner - vehicle automotive sale
Garage kept for ten plus years, doesn’t run but need much. It’s turned over with just fresh oil and gas.chicago.craigslist.org
