Like a factory gm gasket. Just looked and ls9 7 layer is the same thickness.The ones that just came out weren't 7 layer MLS (can't remember what I bought). So I'm not sure what it would be compared to "stock". I don't think it's going to be super low compression, just lower than it just was. Probably mostly due to the larger CC on thr 799s
we’re talking a 61.15 cc head to a 64.45 cc headAre the chambers big enough that you have almost no quench area?
It's a common swap, I'm sure it's fine.Are the chambers big enough that you have almost no quench area?
I mean from the surface that it was facing, not directly onto the pipe, then onto the pipe with wrap.Wrap doesn't work with infrared heat, only thermal
