Disclaimer lots o pics
So I stopped by Pratt's (aka Pressureratio) work to grab the trunk pan, I needed this to see approximately where my cuts would be as this needs replacing.
Before
I have the shop light under the pan so the holes are better seen.
I then drilled pilot holes so I didn't cut the braces. Then I cut out the center rot, I am leaving it like this for a few weeks as it's easier to work being able to stand in the trunk.
Cuts
It was a real bitch finding the spot welds, I sanded down the metal and usually you can tell where the spot welds are by the indentations. No such luck here so it was a lot of guessing. I found common spot welds on both braces and just pealed the metal back to the next set of spot welds. I fucking hate spot welds!!
About as far as I am going for right now, lots of trimming to do but that will come after the wheel tubs are done and the shock cross member is in.
Wire wheeled and rust converted for now.
Then on to the wheel tubs, I bought a new body saw from Eastwood, the shit ass harbor freight saw was gutless.
Rough cuts for now
Now I have one side under my belt I know this side will go faster.
When I was trimming the wheel well near the passenger seat and floorboard I found more trust metal shelving with its partner in crime JBWeld. I wish I had sent this out for blasting so all of this would have bee found at once.
All that was cut out today
