LS3 nice... Cammed?
Yes, Nickeys stage 1 and they tuned it as well.
LS3 nice... Cammed?
They look great! Did you get dual filiment bulbs for the lows or just sticking with lows?
how did you route it under the hood?
pic plz?
For now just lows but eventually I’m ganna do halos.
So cruising around, the car is just fine. But when I floor it and get up in rpm’s there’s a miss/stutter. I feel the car stop pullling as hard(even though it still pulls) but can hear it in the exhaust. I’m hoping it’s from the ram air and it’s just a lean condition that can be tuned out. I basically went from a 1”x2” opening by the air filter to a gaping 4” hole directly in front of the filter lol. It has a fresh tank of 93 so that’s ruled out.
I also no longer have the air intake resting on the upper radiator hose which made a HUGE difference on intake pipe temp. So it’s also seeing more dense air, on top of that, I’ve been driving it in 50° weather. Sooooo I’m hoping it’s just lean but what’s everyone’s thoughts here? I also changed converters and moved battery to the back but I don’t see that effecting anything.
T clamps are shot for my intake so I ordered new ones. Tightened them up and it got much better. But they come loose on their own and I even snapped one tightening the damn thing. It’s a slight miss too if first but if I’m rolling and floor it, it’ll downshift to 2nd and move tf out. With this new converter, Rpms drop from 6900 to around 6100 after the shift now compared to 5200 last year. Feels great and keeps pulling. Looking at my dyno sheet there’s a 50hp difference between these two rpms.
Everything has under 4500 miles on it so I haven’t checked plugs and valve springs yet. I did groundctye computer directly to the neg on the battery and added a ground strap from where the harness grounds to the back of the head I added a ground to the firewall.
Cause unless it's boosted ain't no loose clamp Gunna cause Lean unless your air filter is plugged. Na engine vacuum isn't that crah
