05 Cobalt eating ICM
GTvert90
Belvidere
I picked up a Cobalt with about 127kmiles. Did some maintenance stuff to it, replaced the plugs, brakes, and so on. Anyway in probably 1k miles it started misfiring and running super rough. Swapped out the coil and ICM from a parts car and it fixed it for about a week. I had new parts ordered and that lasted about 6 weeks... ICM is bad again. I plan on checking the resistance on the circuit between the ICM and computer...I was also told to check the ground ( any idea where it's located? ) And that spark plugs with high resistance could cause the failure so I'm going to replace those as well. Any other ideas would be appreciated
10sec
Did you get an OEM ICM when you replaced the one out of the parts car?
GTvert90
Belvidere
No it was Delphi. I thought about that.... I just don't want to drop money on OEM to have it crap out in a month.
RICH17
Dr. Pussy Slayer, MD
The 007
I had two coil packs go bad in my car and they were "AC deco" units off of amazon. Third one worked. Could just be a bad line of products
GTvert90
Belvidere
I have a little more time let break down the time line. Bought car with 128k miles or so on it. Did some maintenance to it air filters, fuel filter, brakes, spark plugs. It went about a month or 2 ( not very many miles probably around 1K or less) and started having a random cylinder misfire and wouldn't accelerate. For a quick fix I took the ICM and coil off a Saturn I had sitting here with the same engine. it cured the misfire so I ordered a delphi coil and delphi ICM. Before I could put the new parts on the temporary coil and ICM shit out. No big deal maybe its just a coincidence as those parts had over 100k miles. Put the delphi parts on and it lasted 3 or 4 weeks.. So I'm convinced its more than just a coincidence ( I don't believe the ICM I took off the saturn was OEM but it ran fine for 10k miles or so we had the car)
HILROD
ELGIN
What plugs did you put in it? I've seen this with non O.E. plugs mostly the quadruple million platinum plugs in GMs would keek misfiring and eating coils until acdelco plugs were put back in. Not in a Cobalt tho.
