2004 Tahoe 5.3
5w30 Amazon High Mileage Synthetic
GM Filter
Oil level is OK
20psi on cluster gauge warm idle.
Goes up with more RPM as normal
Runs perfect, no abnormal sounds.
I have been getting lower oil pressure recently and I think it has something todo with the oil and filter I am running. I have been running Amazon oil for probably 25K now with zero issues, even after two Black stone analysis, they still say I am getting better results verses my previous M1 oil and M1 filter. I usually change oil every 6-7K (DIC 30-40%) even though blackstone says I should go 10K. About 6K miles ago. 3K on the oil change and 50% on the DIC I started to notice lower than expected oil pressure. Just over 20psi on a warm idle. I thought to myself maybe its time for an early oil change.
After the oil and filter change the pressure goes back to normal. 30psi on warm idle.
Fast forward to a few days ago. I got another 3K and 50% on the oil life monitor and pressure is down again. I'm thinking maybe its time for another oil analysis or go back to the M1. Id really like to NOT change the oil every 3K. But I am not sure what's changed. I have been running this amazon shit for over 25K with no issues. Wondering if a change to the blend or filter? I wouldn't put it past a big company like Amazon to change something to make it work less effective and force the buyer to buy more of it. Not apposed to switch back to M1 either, I am not saving any money buying Amazon anymore.
GM Filter
Oil level is OK
