03' Grand Am GT MAF Issues
Bub
Pitter Patter
Pistakee Highlands
Car is an 03 GT with the 3400, it was throwing an intermediate p0101 code so I changed the maf also threw in a new air filter. now I have p0101 and p0102, when i drive it around town I can't get the lights to come back after I reset them and the car drives perfect. However she drove the car maybe 20 miles a little more and she explains that it dies when slowing down, either backfire or misses and smells like rotten eggs. Getting about 23 mpgs. I inspected the ground and for the MAF circuit and it visually looked fine. I'm curious if I might be dealing with a clogged cat. Thoughts?? Thanks
boostedguy05
not well known
did you make sure it was plugged in............
Bub
Pitter Patter
Pistakee Highlands
also mind you, I do not have a visible CEL, I found the codes by checking the codes on the handheld
the upstream O2 is easy to remove, then test drive with it unplugged and see if power picks up. the vac test is checking idle vac and part throttle load. if manifold vac drops to near zero at less than 100% throttle/100% load then exhaust is restricted
if its over 120k then its even more likely its plugged or nearly plugged
Bub
Pitter Patter
Pistakee Highlands
It stayed at 20hg at idle and at 2500rpm
under load or just high idle in p/n, you need to be loaded, tape gauge to windshield while driving
a broken cat is more likely to cause an intermittent restriction, smack the converter with a mallet /gloved palm and listen for a rattle
Bub
Pitter Patter
Pistakee Highlands
Okay, I was in park during the test, I'll get at it tomorrow, thank you for the insight. I feel like this is what the issue is. Just odd I'm not throwing a code at the 02 or iirc there should be a failed cat code as well
RICH17
Dr. Pussy Slayer, MD
The 007
Whats the mileage? The cat always seem to go bad around 120k
RICH17
The 007
Yea I bet it is a bad cat. I've seen several plugged cat cars with the same symptoms all around that mileage.
Bub
Pitter Patter
Pistakee Highlands
The tits of this ride lasted about a week or two, although the dying was more intermittent it was still happening, swapped the maf again tested for plugged cat, inspected wiring and grounds, only notable find was a dry rotted pinched vac hose for the evap purge. Today was it's worst dying at every stop so I limped to Chevy and they diagnosed ecu. Bleh
Bub
Pitter Patter
Pistakee Highlands
Ecu swapped and it was bum, threw oe back in and car ran without codes. No explanation. Drove it home died again about 30 min away from shop. Faauuuccck
Bub
Pitter Patter
Pistakee Highlands
Now shop is thinking the torque converter is slipping or something. Idk some gm bulliten this car needs to burn
