WhosNext02
- Joined
- May 21, 2008
- Messages
- 20
- Reaction score
- 0
car garage kept in winters. interior is in perfect condition. new tires less then 1k miles ago. New clutch and flywheel in the summer. call 219 484 1331 with questions or email [email protected]
Mods:
4.6 LITRE SOHC V8
SHORT BLOCK HOT TANKED, BLUE PRINTED AND BALANCED
BORED .30 OVER
EAGLE FORGED CRANKSHAFT
EAGLE H-BEAM CONNECTING RODS
SPEED PRO PISTONS
TOTAL SEAL CHROMEOLY RINGS
NEW BEARINGS THROUGHOUT ENGINE
PEFORMANCE IMPROVEMENT CYLINDER HEADS WITH STAGE I PORT WORK AND POLISHING
STAGE III COMP CAMS CAMSHAFTS 242/246 DURATION @ .050 .550/.550 LIFT(Nitrous Cam)
STAGE III COMP CAMS VALVE SPRINGS
BBK ALUMINUM MODULAR V8 VALVE COVERS
FORD INTAKE WITH PORT WORK TO MATCH CYLINDER HEAD PORTING
FORD MOTORSPORTS 30LB FUEL INJECTORS
FORD MOTORSPORTS 80MM MASS AIR FLOW METER
BBK FENDER MOUNT COLD AIR INTAKE
FORD UNDERDRIVE PULLEYS
ALUMINUM RADIATOR WITH ELECTRIC FANS
TRANSMISSION:
TREMEC HEAVY DUTY TKO 5 SPEED TRANSMISSION
PRO 5.0 SHORT THROW SHIFTER
SPEC STAGE 2+ ANTI SLIP RACE CLUTCH
FORD MOTORSPORTS ALUMINUM DRIVESHAFT
Richmond 430 RING AND PINION
BBK FULL LENGTH SUB FRAME CONNECTORS
BBK Long Tube Chrome Headers
BBK X-pipe no cats
Flow master 40 series cat-back
Mods:
4.6 LITRE SOHC V8
BORED .30 OVER
SPEED PRO PISTONS
TRANSMISSION:
BBK X-pipe no cats
