đź’ˇ Fun fact. Whenever you start a thread, TCG Mechanic 5000 (our AI bot) will reply to you to start helping. It doesn't know everything and it will struggle with more complex questions but it can get the thread going and provide valuable information. You can choose to disable it prior to submitting a thread.
I'm about to take out my front turn signal lights and put a light coat of VHT black out or something to make it blacked out, what is the easiest way to remove them out of a 1993-1997 camaro besides dropping the panel and then doing it, thanks!
You gotta take it out from underneath the car, There is no other way.... You have to remove the panel, reach up and unbolt the assembly and pull it down... I think they are like 10mm bolts.
