http://www.strangeengineering.net/
EXCELLENT PRICING! PM or post with your needs and ill get prices to you.
installation also available!!
yes im a vendor, dealer, whatever you want to call it.so what youre saying here...is that you are a vendor for strange? trying to make your post far less vague
Looking for pricing on a series 2 carrier 3.73 gear set with master install kit.
Parts numbers look like RS01875373X and R5218. I think that's it, the print is a little hard to read.
ill have answers for you both tomorrow(monday).do they have a setup for a 04 chevy silverado 1/2 ton 2wd 8.6"gear 10 bolt? looking for a housing and axle combo. i have a tru-trac and gears to go into it.
185 for gearLooking for pricing on a series 2 carrier 3.73 gear set with master install kit.
man you got an odd ball... there is nothing avalible for your application.do they have a setup for a 04 chevy silverado 1/2 ton 2wd 8.6"gear 10 bolt? looking for a housing and axle combo. i have a tru-trac and gears to go into it.
PM sentLooking for a rear end for my 99 camaro. Thinking 12 bolt? it has a 373 gear right now in the stocker 10 bolt. Already broke it a few times and shucked the spider gears off of it.
If it helps it has a series 3 in it right now I believe? and the abs is on the wheels not the housing.
185 for gear
100 for
thats tax included.
ill ask martay what he wants to do the install.
BUT! if your stock axle is a large GM housing end, we could get you some strong axles, a gear, and c-clip eliminators.
or... we could go a S60, 9", or 12bolt. all we would need is measurements. and you wouldnt be able to run your stock brakes anymore on the back.
