My name is Patrick, i have a modded 1990 Thunderbird Supercoupe I was told about the site by JDHedman. I look forward to meeting you all at future events
Idle video link click ME
Engine Modifications:
DIS-4 MSD ignition box
180 degree tstat
Dyno tune by dave
taylor 8mm spiro pro spark plug wires
Installed, gapped, and indexed spark plugs. Autolite 103
k&n 9" cone airfilter
mp cold air divider
mp 3.5" intake tube
mp 85mm throttle body
mp front mount intercooler system
mp polished raised top
mp inlet plenum
mp tensioner springs
10% OD MP crankshaft pulley
magnaport2 supercharger
removed air silencer
kooks midlength headers with ceramic coating
2.5" downtubes with highflow cats
magnaflow resonator dual 2.5" inlet single 3" outlet
flowmaster catback system with 3" center pipe in place of 2.5"
255lph fuel pump
billet adjustable fuel pressure regulator
c&l 76mm mafs
60# fuel injectors with cl sample tube
5% overdrive pulley
solid motor mounts
Complete felpro gasket set with mls head gaskets
ARP head studs
timing chain and tensioner set
Custom cam 571/579
Durabond cam bearing set
Chrome Moly 5/16" .080" wall pushrods. Custom length
Scorpion roller rockers 1.73
Stage I ported heads by Dave. Includes oversize valves, springs, hardware
Lower intake manifold ported to match heads
Sealed Power connecting rod bearing set
Sealed Power A-series main bearing set
Replace main and rod bearings with assembly still in block
BHJ Harmonic balancer
Custom aluminum radiator
Drivetrain Modifications:
heavy duty trans cooler
transmission completely rebuilt with better internal parts
2300 stall torque converter
additional clutches for all gears
trans-go shift kit
3.73 rear gear ratio with correct speedo gear
rebuilt rear end 8.8"
Suspension Modifications:
17x9 '03 cobra r polished rims
nitto 555 245/45/17 front
MT ET street radials 275/40/17 rear
Future Plans:
Fiberglass doors - working on gettin them on the car now
sc ram-air hood
Fiberglass trunk lid - shipped today
new paint job
before
after
180 degree tstat
Dyno tune by dave
mp cold air divider
mp 3.5" intake tube
mp inlet plenum
255lph fuel pump
c&l 76mm mafs
5% overdrive pulley
solid motor mounts
ARP head studs
Custom cam 571/579
trans-go shift kit
Future Plans:
sc ram-air hood
new paint job
before
after
