Here is my progress so far with this kit. The quality of the cnc machined parts, individually labelled bags with tags and the instruction manual for installation was all first class. The guys at Ptuning were always willing to answer any questions I had regarding installation etc.
Ap1 2002
ACT Clutch 11.5lb flywheel
Ptuning GTX3076r with oil cooler and thermostat
ATP Inconel wrapped manifold and turbo
Fullblown rad
Ptuning 3 inch dual exhaust with open dump
Stock motor probably going to upgrade valve retainers this spring
AP2 front bumper with cr lip
Hondata Kpro EMS
ID 2200 or 214lb injectors for E85. Could have gone smaller ID 1000 injectors but would need to raise fuel pressure to flow enough
Aeromotive 340LPH Pump. This pump is super quiet
Hondata Map Sensor
AEM Wideband/boost
17 inch AP2 wheels polished
ATP Inconel shielding
Custom CNC machine engine mount for turbo
Trans tunnel support for 3 inch exhaust
Oil cooler and thermostat
Oil pump to oil cooler and then back to engine, no gravity drain
Ap1 2002
Fullblown rad
Hondata Kpro EMS
Hondata Map Sensor
AEM Wideband/boost
