The Chicago Garage
*Luke's* Register Members Casino Live Posting Garage Arcade Register iTrader Members List Calendar Search Today's Posts Mark Forums Read
Go Back   The Chicago Garage > The Garage > 3800 Discussion
br
Reply
Thread Tools Search this Thread Display Modes
Old 02-06-2010, 06:54 PM   #1
Eagle
2 steppin fool
Eagle's Avatar
Casino cash: $4474000
20.03 per day
Default Threw a P0128
Why suddenly would my car start doing this?
Quote:
DTC P0128
Circuit Description
An engine coolant temperature (ECT) sensor monitors the temperature of the coolant. This input is used by the powertrain control module (PCM) for engine control and as an enabling criteria for some diagnostics.
The air flow coming into the engine is accumulated and used to determine if the vehicle has been driven within the conditions that would allow the engine coolant to heat up normally to the thermostat regulating temperature. If the coolant temperature does not increase normally or does not reach the regulating temperature of the thermostat, the diagnostics that use ECT as enabling criteria may not run when expected.
This DTC will only run once per ignition cycle within the enabling conditions. If the PCM detects the calibrated amount of air flow and engine run time have been met, and the ECT has not met the minimum thermostat regulating temperature, DTC P0128 sets.
Conditions for Running the DTC
DTCs P0101, P0102, P0103, P0112, P0113, P0116, P0117, P0118, P0125, P0502, P0503 are not present.
The startup ECT is less than 75°C (167°F).
The intake air temperature (IAT) is more than -7°C (+19°F).
The engine run time is between 30-1,800 seconds.
The vehicle is driven more than 0.8 kilometers (0.5 miles) at more than 8 km/h (5 mph).
Conditions for Setting the DTC
The PCM detects that:
The calibrated amount of engine run time has been met.
The calibrated amount of engine air flow has been met.
The calibrated vehicle speed and distance have been met.
The calibrated ECT of 80°C (176°F) has not been met.
IN OTHER WORDS, BAD T-STAT OR ENGINE COOLANT TEMP SENSOR
__________________
Eagle is online now
  2002 WS6; 2000 GTP
Old 02-06-2010, 07:38 PM   #2
K J
Hillbilly
K J's Avatar
Casino cash: $3032000
12.98 per day
Send a message via AIM to K J
Default
whats your temps doin
__________________
01 gtp. turbos are good.
06 300c srt8. hemi's are cool.
03 awd vibe. for sale soon. inquire within.
BUILTnotBOUGHT racing. coming on strong 2010.
K J is offline
     Grand Pricks    HP: 12    TQ: 35    @ 101
Old 02-06-2010, 07:44 PM   #3
TommyGloves
I ♥ E85
TommyGloves's Avatar
Casino cash: $611403
1.67 per day
Default
What t-stat (deg) do you have installed? Like KJ said...what are your temps doing?
__________________
1999 Grand Prix GTP (Sponsored by PANDA Racing) | 2003 Bonneville SSEi (Sponsored by DD Racing)
2007 Saab 9-7x 5.3i (Sponsored by Skeezer Racing) | 2001 Aztek GT
3800 Tuner/Member of DD Racing, TG Racing, PANDA Racing and BaB Racing. (All members of the {Insert Name Here} Racing Consortium.)
Need your junk cleaned? www.perfectautofinish.com
Need your 3800 trans rebuilt or heads ported? www.tripleedgeperformance.com
Need a replacement 3800/GM FWD part? www.moradpartscompany.com
TommyGloves is offline
  03 SSEi & 99 GTP
Old 02-06-2010, 08:05 PM   #4
Stink Star Productions
BILLY MAYS HERE
Stink Star Productions's Avatar
Casino cash: $416004
3.32 per day
Default
if it were a ECT sensor it would throw a over/under voltage code 99% of the time.... i would suspect a stuck open thermostat, as that usually fixes this code.....
__________________
my name is Boosh.
IF MY MESSAGE LOOKS LIKE THIS, IM NOT YELLING... MY CAPS LOCK IS JUST ON BECAUSE IM SLACKING AT WORK AND THE COMPUTERS AT WORK NEED CAPS LOCK STUCK ON
Stink Star Productions is online now
  2005 CTS-V
Old 02-06-2010, 08:23 PM   #5
Eagle
2 steppin fool
Eagle's Avatar
20.03 per day
Default
Temps seem fine, car still makes fine and good heat... its a 180* AFAIK
__________________
Eagle is online now   Reply With Quote
Old 02-06-2010, 08:32 PM   #6
TommyGloves
I ♥ E85
1.67 per day
Default
Did you recently change the fan settings or are you running stock? Can you get a scan with ETC?
FWIW - I get this code on my SSEi once it gets cold out so I swap out my 180* for the 195*.
I've got an extra 195 t-stat (used) if you want it. (just come pick it up.) LMK
__________________
TommyGloves is offline   Reply With Quote
Old 02-06-2010, 08:32 PM   #7
Eagle
2 steppin fool
Eagle's Avatar
20.03 per day
Default
I havent changed anything and it just started doing this over the past 2 days or so
__________________
Old 02-07-2010, 02:56 AM   #8
02SSEi
Gimme some chili Fritos
02SSEi's Avatar
Casino cash: $2010257100
11.67 per day
Send a message via AIM to 02SSEi
Default
I run a drilled 180 year round with no problem. Car hardly ever gets up to operating temps either. No codes.
02SSEi is offline   Reply With Quote
Old 02-08-2010, 04:21 PM   #9
firemandan1700
Just another day at the office
firemandan1700's Avatar
Casino cash: $485089
2.16 per day
Send a message via AIM to firemandan1700 Send a message via Yahoo to firemandan1700
Default
i never got this code until i put headers on my car. like it has anything to do with it anyways.
i just ignore it.
__________________
2001 Trans Am WS6 A4 (1 of 630)
2002 GTP- Intake and some pipes
1966 Chevelle- Under Construction
2007 Suzuki GSX-R 600- Sold
firemandan1700 is offline
     02 GTP    HP: 240    TQ: 280
Old 02-08-2010, 05:42 PM   #10
phat_ridegt
SLOW GTP
Casino cash: $570900
2.52 per day
Send a message via AIM to phat_ridegt Send a message via Yahoo to phat_ridegt
Default
more than likely its been a co-incidence that you never got a 128 code before with a 180 stat....
it could be sticking open...but just clear it with your tuner...nothing to worry about if your temp gauge works
__________________
T67/ST5--11.47 @ 120.85 17psi
ZZP Recommended Installer
phat_ridegt is online now   Reply With Quote
Old 02-09-2010, 01:14 AM   #11
02BlueGT
......I got nothing
02BlueGT's Avatar
Casino cash: $1171540
6.18 per day
Send a message via AIM to 02BlueGT
Default
Quote:
i just ignore it.
The ECT is very close to the exhaust, a badly routed, or just too close to the sensor setup could cause ECT problems
__________________
2002 GP GT
off 10secsomeday since 2009
Member of DD racing
02BlueGT is offline
     Official Race Car DD    HP: 999    TQ: 15    @ 350
Old 02-09-2010, 04:36 PM   #12
firemandan1700
2.16 per day
Default
Quote:
i made sure my gauge is constant with my scans and it does
__________________
firemandan1700 is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This site is dedicated to the memory of Chris Beckmann
Forums Directory
no new posts
